It is currently Sun Jul 27, 2025 7:51 pm
PostPosted: Tue Aug 30, 2005 12:27 pm
I've a Beltona Blue uke. It's a fiberglass uke with a
biscuit cone. I've had a great time with it, but want to
tackle one of my own. Since it's fiberglass, the well
is built as one piece with the body. In short, there is
little to learn from this uke about how to construct a
reso from traditional materials.
I'd like to build a wood one (and later brass) and
need to build the well.
I've laminated 1/2" maple and plan to turn the well on
the lath. Is this the right approach? Is there
another/easier/better way?
PostPosted: Tue Aug 30, 2005 5:10 pm
G.B., I haven't seen a Reso-Uke apart so I can only guess it may be similar to a guitar in a scaled down version.
If it is a sound-well it could be laminated around a form with veneer. If it's a ring it could be made from a good grade of Plywood.
PostPosted: Tue Aug 30, 2005 6:21 pm
I've not made a uke (yet) but for guitars I usually cut out the ring from ply and then laminate the sides of the well around it using birch modellers' ply. It's long-winded but I don't like having thick walls for the well.
Incidentally, Fine Resophonics are about to start producing dobro-style uke spider cones and spider bridges. Details hereLouisianaGrey38595.142349537
Pete
PostPosted: Wed Aug 31, 2005 1:40 am
I've had a line on the Fine Reophnics cones since
their inception. I have a National cone and bicuit
under my bench. I want to get one or two of these
under my belt before I buy the fine reso spider cone.
Geoff
Users browsing this forum: Bing [Bot] and 10 guests
